Combining multiple FS in one
Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
Is it possible to have several different FS in one?
Meaning I would like to create an enum that will allow you to choose which FS you want to use.
I know the work around here is to just physically copy and paste and have it work that way, but I don't want that.
I would like to be able to import in to a new FS all of my different features so that I can secure my code.
example:
FeatureScript 392;
import(path : "onshape/std/geometry.fs", version : "392.0");
FS1::import(path : "123123123123123", version : "321321321321");
FS2::import(path : "456456456456456", version : "654654654654");
export enum Choice
    annotation {"Name" : "FS1"}
    ONE,
    annotation {"Name" : "FS2"}
    TWO
annotation { "Feature Type Name" : "Creation Choice" }
export const myCreationChoice = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "My Enum" }
        definition.myChoice is Choice;
        if(definition.myChoice == Choice.ONE)
            run function FS1
        if(definition.myChoice == Choice.TWO)
            run function FS2
Digital Engineering
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,263 image
  • Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
    @ilya_baran would the copy/paste also hold true for the export enum options I have within my other FS?
    Also, I'm not %100 on the "FS1::firstFeature(context, id, definition);" part.. would that be the "myFeature" that is placed when you create a new FS?
    The "const" would all have to be copy/paste as well?
    @mahir so instead of my "FS1::import....." I would have to put "export FS1::import......" in it's place?
    Is there a good example out there that does this?
    Digital Engineering
    No, the enum declarations need to be reexported, not copied.  Doing "export FS1::import" instead of "FS1::import" will do that.
    Yes, the default function name is "myFeature".
    Not sure what you mean about "const" copy/pasting, but yes, you need the boilerplate in your example above.
    @ilya_baran forgive me for my lack of knowledge/understanding... But what would go in the "(context, id, definition)" arguments?
    This is what I have so far....
    This is the document that I am trying to get the 2 FS options to import in to.
    https://cad.onshape.com/documents/5a4159c08aa167c04de8c637/w/c4d507ef42bda6d297b57fb9/e/1d6f216f1df1cea430821a9c
    This is the document that is holding the 2 working FS.
    https://cad.onshape.com/documents/df4ff84027cc7cd2dde61b6c/w/b8de7280118f711b70aee96e/e/7ea31fe7944222c6fbe064e5
    @lemon1324 - I know you have some experience in this as well, would you mind shining some light on this for me?
    Any questions, please ask... This is kind of an important hurdle I need to jump.
    Thank you.
    Digital Engineering
    Ok, your function body is correct -- (context, id definition) is exactly what goes in there -- you're just forwarding the context, id, and the definition to the other feature.  The problem is the enums -- you are redefining them in the outer FS, which makes them different.
    Unfortunately, you can't reuse the enums within a namespace (the FS1::) and you probably don't want to reexport the original feature without a namespace.  So what I'd do is the following:
    Make a separate feature studio with the enum declarations.  Export import it without a namespace into both other feature studios.  So:
    FS-enums:
    export enum Choice
          ONE,
          TWO
    FS-features:
    export import ( ... FS-enums ... )
    // define your two features
    FS-choiceFeature:
    FS1::import( ... FS-features ... )
    ... FS1::myTableCreator(context, id, definition); ...
    Does this make sense?
    @ilya_baran I'm trying to follow as much as possible without asking many questions, but unfortunately I am unable to follow what you are telling me to do.
    Digital Engineering
    Thank you @ilya_baran
    Digital Engineering
    @ilya_baran
    Should it matter that one of my FS has imported parts?
    I got the desired result, but my TableCreator FS is not wanting to generate.
    I can only speculate that it's because of the imported legs?
    Digital Engineering
    I think it should work with imported legs the way you're doing it.  What's the error you're getting?
    Sorry, you are correct @ilya_baran, I was not working in the latest version.
    All is good and working!!! Thank you so much!!  :)
    Digital Engineering
Howdy, Stranger!
