Grouping Enum
Dylan_Stewart
Member, Developers Posts: 107 PRO
Okay so it's been a little while since I've deep in to FS and I have another hurdle to jump.
I am trying to group my enums instead of having a huge list.
I have a lot of different sketch profiles that will always be together when imported in. I have to separate them due to the complexity of the profile so each part will extrude correctly.
Is there a way to 'bypass' the need for this in the precondition?
What would be better is to be able to group all of the profiles that will be used in to 1 enumerator.
As always, your help is greatly appreciated.
annotation {"Feature Type Name": "Group Enum"} export const myGroupEnum = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation {"Name":"Profile1"} definition.profile_1 is 1profile; annotation {"Name":"Profile2"} definition.profile_2 is 2profile; annotation {"Name":"Profile3"} definition.profile_3 is 3profile; }PROFILES::import(importedDoc/123456.....) export enum 1profile { annotation {"Name":"1"} 123_0 } <pre class="CodeBlock"><code>export enum 2profile { annotation {"Name":"2"} 456_0 } <pre class="CodeBlock"><code>export enum 3profile { annotation {"Name":"3"} 789_0 }This example only uses 3 profiles but I imagine I will have somewhere in the neighborhood of around 20-30...
Digital Engineering
@Dylan_Stewart, I'm not sure what the desired end result is, but I don't see why you can't just code the desired behavior into a branched if/else based on an initial selection.
If (definition.profile =="123")
...import profiles 1, 2, 3
else if (definition.profile == "456")
...import profiles 4, 5, 6
else if (definition.profile == "789")
...import profiles 7, 8, 9
Another option is to group your profiles into an array of sub arrays that separates and organizes all the various profiles.
var profiles as array = [ [1a, 1b, 1c, 1d], [2a, 2b], [3a, 3b, 3c] ]
Then, depending on which enum is selected, you can load all the profiles in either profiles[1], profiles[2], or profiles,[3].3
It sounds like you want a single enum defined with several options. With n profiles, you'll need n imports into n namespaces, but only one parameter and one list of options. Here' an example:
FeatureScript 422; import(path : "onshape/std/geometry.fs", version : "422.0"); // Created using import button above PROFILE_1::import(path : "b43fcf52027e641d12c6e75b", version : "b9ff861b36c4801a846c3058"); PROFILE_2::import(path : "fad6bab7c868aa7808a486c2", version : "545623d9717aa6a186745075"); PROFILE_3::import(path : "e81df29897b702fb3c66444f", version : "b889912552d569e0c391aa74"); export enum Profiles { annotation {"Name":"1"} p123_0, annotation {"Name":"2"} p456_0, annotation {"Name":"3"} p789_0 // etc. } annotation {"Feature Type Name": "Profile chooser"} export const profileChooser = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation {"Name" : "Profile"} definition.profile is Profiles; annotation { "Name" : "Size" } isLength(definition.size, LENGTH_BOUNDS); } { println("Profile chosen is " ~ definition.profile); var profileContext; if (definition.profile == Profiles.p123_0) profileContext = PROFILE_1::build(); if (definition.profile == Profiles.p456_0) profileContext = PROFILE_2::build(); if (definition.profile == Profiles.p789_0) profileContext = PROFILE_3::build(); // etc. // Delete construction planes and lines, leaving just a sketch region const profileRegion is Query = qConstructionFilter( qEverything(EntityType.FACE), ConstructionObject.NO ); const profileBody is Query = qOwnerBody(profileRegion); opDeleteBodies(profileContext, id + "deleteBodies1", { "entities" : qSubtraction(qEverything(EntityType.BODY), profileBody) }); opMergeContexts(context, id + "mergeContexts1", { "contextFrom" : profileContext }); opTransform(context, id + "transform1", { "bodies" : qCreatedBy(id + "mergeContexts1", EntityType.BODY), "transform" : scaleUniformly(definition.size / (1 * inch)) }); opExtrude(context, id + "extrude1", { "entities" : qCreatedBy(id + "mergeContexts1", EntityType.FACE), "direction" : vector(0, 0, 1), "endBound" : BoundingType.BLIND, "endDepth" : 0.125 * inch }); });And here's a document using this code: https://cad.onshape.com/documents/d7defad80f5b58678d7702f7/w/629ed705a4e5996689b1d2b9/e/335044dc6622d08bb86f8e9a
Let us know if you have more questions!0 -
Yes, that would allow you to make a choice between all of the imported profiles, but I need something that will build all of the profiles without having a huge list of 20 or so options.
Grouping all profiles would be ideal, as there may be some options later on down the line and that's when I would like to introduce the idea of the drop-down menu.
Basically, I need to build a group of profiles automatically while only using 1 option from the menu.Digital Engineering0 -
Then, depending on which enum is selected, you can load all the profiles in either profiles[1], profiles[2], or profiles,[3].3 -
No problem
The other option may be to use a lookup table, as the Onshape hole feature does, but I'm not sure if you can use that to set non-numeric values.Arul Suresh
PhD, Mechanical Engineering, Stanford University0 -
@lemon1324
You can use a lookup table to look up any FeatureScript value, not just numbers. You could even have that value be a FeatureScript map with many values inside.1
