Grouping Enum
Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
Okay so it's been a little while since I've deep in to FS and I have another hurdle to jump.
I am trying to group my enums instead of having a huge list.
I have a lot of different sketch profiles that will always be together when imported in. I have to separate them due to the complexity of the profile so each part will extrude correctly.
annotation {"Feature Type Name": "Group Enum"}
export const myGroupEnum = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation {"Name":"Profile1"}
definition.profile_1 is 1profile;
annotation {"Name":"Profile2"}
definition.profile_2 is 2profile;
annotation {"Name":"Profile3"}
definition.profile_3 is 3profile;
}PROFILES::import(importedDoc/123456.....)
export enum 1profile
   annotation {"Name":"1"}
   123_0
<pre class="CodeBlock"><code>export enum 2profile
   annotation {"Name":"2"}
   456_0
<pre class="CodeBlock"><code>export enum 3profile
   annotation {"Name":"3"}
   789_0
This example only uses 3 profiles but I imagine I will have somewhere in the neighborhood of around 20-30...
Is there a way to 'bypass' the need for this in the precondition?
What would be better is to be able to group all of the profiles that will be used in to 1 enumerator.
As always, your help is greatly appreciated.
Digital Engineering
  • mahirmahir Member, Developers Posts: 1,323 ✭✭✭✭✭
    @Dylan_Stewart, I'm not sure what the desired end result is, but I don't see why you can't just code the desired behavior into a branched if/else based on an initial selection.
    If (definition.profile =="123")
    ...import profiles 1, 2, 3
    else if (definition.profile == "456")
    ...import profiles 4, 5, 6
    else if (definition.profile == "789")
    ...import profiles 7, 8, 9
    Another option is to group your profiles into an array of sub arrays that separates and organizes all the various profiles.
    var profiles as array = [ [1a, 1b, 1c, 1d], [2a, 2b], [3a, 3b, 3c] ]
    Then, depending on which enum is selected, you can load all the profiles in either profiles[1], profiles[2], or profiles,[3].
    edited October 2016
    It sounds like you want a single enum defined with several options. With n profiles, you'll need n imports into n namespaces, but only one parameter and one list of options. Here' an example:
    FeatureScript 422;
    import(path : "onshape/std/geometry.fs", version : "422.0");
    // Created using import button above
    PROFILE_1::import(path : "b43fcf52027e641d12c6e75b", version : "b9ff861b36c4801a846c3058");
    PROFILE_2::import(path : "fad6bab7c868aa7808a486c2", version : "545623d9717aa6a186745075");
    PROFILE_3::import(path : "e81df29897b702fb3c66444f", version : "b889912552d569e0c391aa74");
    export enum Profiles
        p123_0,
        p456_0,
        p789_0
        // etc.
    annotation {"Feature Type Name": "Profile chooser"}
    export const profileChooser = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation {"Name" : "Profile"}
        definition.profile is Profiles;
        annotation { "Name" : "Size" }
        isLength(definition.size, LENGTH_BOUNDS);
        println("Profile chosen is " ~ definition.profile);
        var profileContext;
        if (definition.profile == Profiles.p123_0)
            profileContext = PROFILE_1::build();
        if (definition.profile == Profiles.p456_0)
            profileContext = PROFILE_2::build();
        if (definition.profile == Profiles.p789_0)
            profileContext = PROFILE_3::build();
        // etc.
        // Delete construction planes and lines, leaving just a sketch region
        const profileRegion is Query = qConstructionFilter(
            qEverything(EntityType.FACE),
            ConstructionObject.NO
        const profileBody is Query = qOwnerBody(profileRegion);
        opDeleteBodies(profileContext, id + "deleteBodies1", {
                "entities" : qSubtraction(qEverything(EntityType.BODY), profileBody)
        opMergeContexts(context, id + "mergeContexts1", {
                "contextFrom" : profileContext
        opTransform(context, id + "transform1", {
                "bodies" : qCreatedBy(id + "mergeContexts1", EntityType.BODY),
                "transform" : scaleUniformly(definition.size / (1 * inch))
        opExtrude(context, id + "extrude1", {
                "entities" : qCreatedBy(id + "mergeContexts1", EntityType.FACE),
                "direction" : vector(0, 0, 1),
                "endBound" : BoundingType.BLIND,
                "endDepth" : 0.125 * inch
    And here's a document using this code: https://cad.onshape.com/documents/d7defad80f5b58678d7702f7/w/629ed705a4e5996689b1d2b9/e/335044dc6622d08bb86f8e9a
    Let us know if you have more questions!
  • Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
    Yes, that would allow you to make a choice between all of the imported profiles, but I need something that will build all of the profiles without having a huge list of 20 or so options.
    Grouping all profiles would be ideal, as there may be some options later on down the line and that's when I would like to introduce the idea of the drop-down menu.
    Basically, I need to build a group of profiles automatically while only using 1 option from the menu.
    Digital Engineering
    @mahir
    I believe this is going to be my solution. Thank you!!
    Digital Engineering
    No problem :smile:
    The other option may be to use a lookup table, as the Onshape hole feature does, but I'm not sure if you can use that to set non-numeric values.
    Arul Suresh
    @lemon1324
    You can use a lookup table to look up any FeatureScript value, not just numbers. You could even have that value be a FeatureScript map with many values inside.
