How to make a circular pattern of a revolve?
to_cato_ca Member Posts: 13
I am trying to create an enclosed gear to hold a beaded cord. I can create a cylinder with a single semisphere cut out. I then saw the circular pattern feature, which seemed perfect. However when I use it it seems to go wrong. The first time I used 'new' which just created a shape inside a shape of course. Now I'm trying to use 'remove', but now I get an error.
My document is here
    bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
    The way I would approach it is to use the revolve to create the sphere as a new part. Then use the Circular Pattern > remove option. This will cut the sphere into the cylinder and even get rid of it for you after the action is complete: https://cad.onshape.com/documents/6df6eb576dc7b1e5066caa73/w/899142034f3ca7ead9d915ae/e/a7fe6ae67d6600e71f9b0cd6
    Twitter: @bradleysauln
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,178
    The other option is to do a face pattern instead of a part pattern.
    mahirmahir Member, Developers Posts: 1,291 ✭✭✭✭✭
    Or yet another method, use a feature pattern to pattern the revolve cut feature.
    @mahir
    That will work, but feature patterns take longer to regenerate than part or face patterns (because they reapply the features, not just replicate the geometry).
    Thanks Bradley, this is what I did. I created a single sphere and then when I used the repeat I did it with remove. I was a bit confused conceptually because I assumed the the circular repeat would repeat the removal, but I think what it did was repeat the shape inside the original shape, leading to confusing results.
