How to make a circular pattern of a revolve?
to_ca
to_ca Member Posts: 13 ✭
I am trying to create an enclosed gear to hold a beaded cord. I can create a cylinder with a single semisphere cut out. I then saw the circular pattern feature, which seemed perfect. However when I use it it seems to go wrong. The first time I used 'new' which just created a shape inside a shape of course. Now I'm trying to use 'remove', but now I get an error.
My document is here
  • bradley_sauln
    bradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    The way I would approach it is to use the revolve to create the sphere as a new part. Then use the Circular Pattern > remove option. This will cut the sphere into the cylinder and even get rid of it for you after the action is complete: https://cad.onshape.com/documents/6df6eb576dc7b1e5066caa73/w/899142034f3ca7ead9d915ae/e/a7fe6ae67d6600e71f9b0cd6
    Twitter: @bradleysauln
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,273 image
    The other option is to do a face pattern instead of a part pattern.
  • mahir
    Or yet another method, use a feature pattern to pattern the revolve cut feature.
  • ilya_baran
    @mahir
    That will work, but feature patterns take longer to regenerate than part or face patterns (because they reapply the features, not just replicate the geometry).
  • to_ca
    Thanks Bradley, this is what I did. I created a single sphere and then when I used the repeat I did it with remove. I was a bit confused conceptually because I assumed the the circular repeat would repeat the removal, but I think what it did was repeat the shape inside the original shape, leading to confusing results.
