Loft square to circle
https://cad.onshape.com/documents/f5e861743c7363c047d2ad61/w/17b61a3cdbff783ff4a5784f/e/23e5f9cd50f0c351e09ede81
I'm trying to loft a square to a circle. Lofting a solid between the two faces gives the error "Cannot use faces or regions with inner loops as profiles". Lofting a surface between the inner edges of the two faces gives the error "Could not align profiles to loft direction". Since one side is 4 edges and the other is just one, it seems like I need a way to specify start vs. end edges, or to group edges, but I can't figure out how to do either.
Help?
