How fix part in assembly and How to align a part face to x,y or z direction in assembly?
suyog
Member Posts: 1 ✭
Hello
As the parts are not fixed my whole assembly is not in correct orientation with respect of coordinate system.
So how to align a assembly facing in x or y or z direction.
and how to fix part so that while mating constraints no parts move with respect to fixed part.
1
You can place a mate connector on the origin and orient it such that its z-axis aligns to any of the 3 normal axes. Then fasten your first part to that mate connector (using a Fasten mate) and orient it as you would like.4
This worked perfect,thanks! You're a lifesaver!brian_brady said:You can place a mate connector on the origin and orient it such that its z-axis aligns to any of the 3 normal axes. Then fasten your first part to that mate connector (using a Fasten mate) and orient it as you would like.
1
