Extrude issue removing from extruded shape
professor_quack
Member Posts: 3 ✭✭
Hi,
I'm having trouble with extrude remove only removing one layer of the surface. The layer it doesn't penetrate is an extruded solid
My project is linked here. https://cad.onshape.com/documents/5816f7d62940cb10571d4c70/w/38919ae4839eaf2f08d02bfc/e/b12f264a1d3ef866a9183758
Edit "Extrude Lip" and change it from "New" to "Add" and "Merge with all"Senior Director, Technical Services, EMEA1
Many thanks that works great! I'll research what that setting actually means now.0
@professor_quack , please do not forget there is a tutorial page in Onshape, http://www.onshape.com/learn/cad-tutorials#top , it is very helpful for learners.
