How to engrave text?
drcontempo
Member Posts: 5 ✭
How can you engrave text?
I've been using the curved text feature script but I think there are still a few bugs? The "add" doesn't actually add to the solid model and instead creates a new part for every letter.
And the cutout option just extrudes all the way through the part?
Thanks for any help!
Correct me if I am wrong @dave_cowden.
The only thing I can think of is your surface reference doesn't actually rest on the body you are trying to boolean with. The feature will try to do a boolean add with everything it can if 'Raised Add' is selected. If your 'Base Surface' is offset, the feature will create new parts for every letter instead of failing completely.
Jason
Support & QA1 -
@Jason_S thanks for pulling me in.
@drcontempo Jason's guess is reasonable, but if that doesn't work please share a document that you are having issues with and I will have a look.
I am not aware of any outstanding bugs with the 3d text feature at the moment, but that doesn't mean they don't exist!0 -
@drcontempo, Here's a cool "emboss" FeatureScript from @dave_cowden: https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/w/24132f252a02825eb0606641/e/67f132612739f155f5474819
