Pro tip assembly part orientation
Research_01
OS Professional, Mentor, Developers Posts: 301 PRO
So I want to have my models square to the world. In an assembly this can be a challenge. So my tip is to insert a part and fix it (maybe make a dummy cube), then reference that part to orient one part by using a fasten mate. Fix the part you have just moved, delete the mate and then unfix and delete the dummy part or unfix the original fixed part. Delete the dummy if necessary and voila!
https://drive.google.com/file/d/0B2jg86-MLAyFZll5Yl9hODkyUVU/edit?usp=sharing
This discussion has been closed.
I presume that you would prefer to have some reference geometry to mate to instead?
If so, what types would you like?
LearnOnshape facebook group
Aligning origins is also a good thing for master modeling techniques.
This is all true for the strictly parametric world. In IronCAD I couldn't care less about mating conditions.
Dries
