Turning a 2D cross section into a 3D drawing
ryan_lusher
Member Posts: 3 ✭
Hello
Looking for some help. I am a cable draughtsperson. I draw out cross sections of cables all day but was wondering if there is away using Onshape to convert them into a 3D drawing. There doesn't have to be twists or anything. I just need help designing it as I have never really used any 3D drawing packages before. It would be good if I could show a bit of each i.e. the copper, then the insulation, then the sheath material. Like in a layer I guess is the best way to describe it. Any help would be much appreciated.
Thanks in advance.
Thanks in advance.
Onshape should be good for that. You could even do renderings with a partner package. Below is a quick model of what I think you describe; see https://cad.onshape.com/documents/7d99456e6fb93b2e778d2214/w/d6a7bcc7df9f93ffb712287c/e/b536b9698957ce2dd5fe2152
If you need help starting, I suggest the Onshape videos. see - https://www.onshape.com/learn/cad-training
www.accuratepattern.com5
www.accuratepattern.com5 -
www.accuratepattern.com0 -
Check out the Wiring featurescript. It might be useful.
https://cad.onshape.com/documents/5786b9cce4b0e6bf978a8b9c/w/2af807e3cd318f41a0f73479/e/65a90b7e27f8a1a30d546b93
That's funny. No clue, @bruce_williams. Forum glitch I guess ¯\_(ツ)_/¯0
Because it's such a great post!
Senior Director, Technical Services, EMEA0 -
Thank you for all your input. Yes Bruce that is exactly what I am looking for. I have just no experience in 3D working so I shall take a look at what you said and maybe get back in touch if I am still having trouble with it.0
