Why won't my loft guides work?
jon_woellhaf
jon_woellhaf Member Posts: 92 ✭✭✭
In this document https://cad.onshape.com/documents/e2280f6ae9ff233bf39c4a43/w/eaa4cd2376f9ed0516d72aa8/e/13d08a48b7ef944b575d899e I am unable to get the guides in the sketch "vertical guides" to be accepted by Loft 2.
The dialog complains that the guides do not intersect each profile boundary, but with constraints showing, they appear to be properly pierced.
What am I missing?
  • TimRice
    TimRice Member, Moderator, Onshape Employees Posts: 315 image
    edited December 2016
    Hey Jon, I took a look at your document and was able to find a solution to the problem. It appears that the upper guide in the "Vertical guides" sketch had a spline handle that was in the same plane as the base sketch. I simply deleted the horizontal constraint and the sketch solved. In the screenshot below I circled the fixed spline point.
    Onshape, Inc.
  • jon_woellhaf
    Tim,
    Thanks very much for the reply. I think I follow, and I see the horizontal constraint on the spline handle. However, when I delete the handle the sketch still doesn't solve.
    Jon
  • Jake_Rosenfeld
    Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646 image
    Hi Jon,
    I think Tim meant for you do delete the constraint, not the handle itself.
    Hopefully this helps.
  • jon_woellhaf
    Yes. My bad. I deleted the constraint, not the handle. No joy.
