Extrude From (again)
Armindilo
Member Posts: 31 ✭✭
I originally added this as an Improvement Request, but got the response that it is already available. However, the explanation offered doesn't actually work, or at least I can't get it to work. And I can't seem to add any further comments to that thread since it has been answered or closed.
The original thread is here: https://forum.onshape.com/discussion/5446/extrude-from
I want to be able have my sketch on the Top Plane (for example) but start my extrude from a parallel face that is not on the Top Plane, and then specify my end condition as normal (Blind, To Vertex, To Face, etc...). Basically have a Start Condition as well as the existing End Condition.
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,436Extrudes are measured from the sketch plane so you will have to create another sketch on the top face. You can use the "use" command in sketch to copy the entities from the first sketch.Senior Director, Technical Services, EMEAI5
Your suggestion is what I have three now, but it doesn't give the functionality I want. That only allows me to specify the distance from the sketch plane up to the second face. It doesn't give me any way to specify a distance down from the selected face.
In my screenshot there, the 2" specified is from the plane up to the bottom of the extrude. I want to specify the actual length of the extrude (10" in the screenshot)
I thought maybe I was missing something since my Improvement Request was marked as Already Available, but it doesn't seem to be.
I guess I will settle for creating another plane. Is there a way to have the original request status changed though, since it isn't actually available as requested?
