Any way to fillet the corner of a surface?
song_jaybi
song_jaybi OS Professional, Developers Posts: 17 ✭✭
edited January 2017 in Community Support
I want to apply fillet at the corner of a surface.
Like this...
  • brucebartlett
    brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
    edited January 2017
    You can't extrude cut a surface or create a surface from a region. You can do a split face to get the region then remove the bit you don't want from the corner with delete face.
    I am looking forward to a suite of surfacing tools, solving some simple problems would be a great start.
  • brucebartlett
    @timrice is right, the delete face will work. I recalled it not working but just checked and it does. I will update my last post.
  • viru
    viru Member, Developers Posts: 619 ✭✭✭✭
    @song_jaybi, Currently in Onshape limited option provided for surface. But at current stage also you get your desired result after performing split face you need to perform delete part operation. Please refer below video for more detail.
  • song_jaybi
    Thank you. @brucebartlett @timrice @viru
    I also hope to be developed a suite of surfacing tool.
    Viru, your sample is very good!!
    I think this way is faster than your example.
    At the split phase
     select type: Face
     Face to split: Surface 1
     Entities to split with: Sketch 3
    Now, This way is best for me.
    Thank you.
