Any way to fillet the corner of a surface?
song_jaybi
OS Professional, Developers Posts: 17 ✭✭
As Bruce mentioned, you could use a split face/part feature to make a cut in the surface. You could then use the delete face/part feature to remove the unwanted portion. A little cumbersome, but should work!Tim Rice | User Experience | Support
Onshape, Inc.5 -
@song_jaybi, Yes your method is fastest and best method. I Forgot to include this method in above video.
5
You can't extrude cut a surface or create a surface from a region. You can do a split face to get the region then remove the bit you don't want from the corner with delete face.
I am looking forward to a suite of surfacing tools, solving some simple problems would be a great start.0 -
Onshape, Inc.5 -
@timrice is right, the delete face will work. I recalled it not working but just checked and it does. I will update my last post.0
@song_jaybi, Currently in Onshape limited option provided for surface. But at current stage also you get your desired result after performing split face you need to perform delete part operation. Please refer below video for more detail.
Thank you. @brucebartlett @timrice @viru
I also hope to be developed a suite of surfacing tool.
Viru, your sample is very good!!
I think this way is faster than your example.
At the split phase
select type: Face
Face to split: Surface 1
Entities to split with: Sketch 3
Now, This way is best for me.
Thank you.0 -
5
