evOwnerSketchPlane not working
cory_isaacson
Member, Developers Posts: 43 PRO
I cannot get evOwnerSketchPlane to work. I give it a query for a body that was extruded from a single sketch, and it gives me the CANNOT_RESOLVE_PLANE, which according to the doc means that the entity was not created from a sketch. It says you should be able to pass a vertex, body, etc.
NeilCooke
Moderator, Onshape Employees Posts: 6,078
Take a look at qDependency - you will have to add other queries to single out sketch entities. If you have multiple sketches belonging to the part, not sure how you will decide which one to choose.Senior Director, Technical Services, EMEA5
