Where'd the document search function go?
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi folks.
Just tried to search for a document having preselected a label and the search box vanished
Is this a bug?
In standard "My Documents" screen it's "Now you see it":-
If I select a label, in this case one called "Common Parts" then it's "Now you don't":-
Chees,
Owen S
| Google Chrome | 56.0.2924.87 (Official Build) (64-bit) |
| Revision | 0e9a9a6f3676ae439b78cd9b3f62b4193c3ac7d5-refs/branch-heads/2924@{#895} |
| OS | Windows |
Chees,
Owen S
Ah, sorry, I thought the box disappeared altogether -- no, I believe we do not currently support searching within a label.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
I think I've seen this type of thing happen with certain Chrome extensions. If you have extensions installed, disabling them will likely make the search box come back.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
@ilya_baran
Thanks for the fast reply.
(1) Just checked Chrome extensions and all I've got is google docs and sheets / slides. With them all turned off the behaviour is the same.
(2) Tried firefox and that did the same.
Perhaps I imagined that this could be done? Does OS support searching within a Label?
Cheers, Owen S.
HWM-Water Ltd0 -
Doh - Owen is mostly feeling silly now.
Thanks anyway.
OwS.
HWM-Water Ltd0 -
owen_sparks,
We are actively working on enhancing the search experience inside Onshape in various areas, would you mind open an improvement request for this for us to better prioritize the functionality.
Thanks0 -
Hi @kevin_guo
Thanks for the reply.
@andy_morris sent me a mail stating that he'd added me to request #53280 so I believe it is in hand and does not require an additional improvement request? If that's not the case and you'd still like me to start a new one I'm happy to do so.
Cheers, Owen S,
HWM-Water Ltd0 -
If I'm not already there, please add me to everything that makes document seach better
//rami0
