Where'd the document search function go?
owen_sparks
edited March 2017 in Community Support
Hi folks.
Just tried to search for a document having preselected a label and the search box vanished :o   Is this a bug?
In standard "My Documents" screen it's "Now you see it":-
If I select a label, in this case one called "Common Parts" then it's "Now you don't":-
Google Chrome56.0.2924.87 (Official Build) (64-bit)
Revision0e9a9a6f3676ae439b78cd9b3f62b4193c3ac7d5-refs/branch-heads/2924@{#895}
OSWindows
Chees,
Owen S
HWM-Water Ltd
  • ilya_baran
    I think I've seen this type of thing happen with certain Chrome extensions.  If you have extensions installed, disabling them will likely make the search box come back.
  • owen_sparks
    @ilya_baran
    Thanks for the fast reply.
    (1) Just checked Chrome extensions and all I've got is google docs and sheets / slides.  With them all turned off the behaviour is the same.
    (2) Tried firefox and that did the same.
    Perhaps I imagined that this could be done?  Does OS support searching within a Label?
    Cheers, Owen S.
    HWM-Water Ltd
  • owen_sparks
    Doh - Owen is mostly feeling silly now.
    Thanks anyway.
    OwS.
    HWM-Water Ltd
  • kevin_guo
    kevin_guo Onshape Employees Posts: 18 image
    owen_sparks,
    We are actively working on enhancing the search experience inside Onshape in various areas, would you mind open an improvement request for this for us to better prioritize the functionality.
    Thanks
  • owen_sparks
    edited March 2017
    Hi @kevin_guo
    Thanks for the reply.
    @andy_morris sent me a mail stating that he'd added me to request #53280 so I believe it is in hand and does not require an additional improvement request?  If that's not the case and you'd still like me to start a new one I'm happy to do so.
    Cheers, Owen S,
    HWM-Water Ltd
  • 3dcad
    If I'm not already there, please add me to everything that makes document seach better
    //rami
