Transform by mate connector bloat
billyzelsnack
Member Posts: 96 PRO
I build mostly machines in onshape so I end up using a lot of different parts more than once. Because of this a large chunk of my main part studio feature list is filled with derived parts of this pattern..
derived - name a
mate - name a
mate - name a
transform - name a
derived - name b
mate - name b
mate - name b
transform - name b
This is both tedious and creates a lot of bloat in the feature list. Is there a better way to go about this?
derived - name a
mate - name a
mate - name a
transform - name a
derived - name b
mate - name b
mate - name b
transform - name b
1
lana
Onshape Employees Posts: 763
If base part studio has a mate connector attached to PartA, it will be present in the part studio deriving partA. Optional transformation in derived feature is a good idea. Please submit an improvement request.1
As for using an assembly context I am forcing myself to build within a main part studio and only use an assembly for visualizing moving parts. It has been a painful process since I am used to using an assembly for, well.. assembling. That said I am starting to become productive again and hopefully it will pay off in the future with better robustness in my models.
I'll go ahead an submit an improvement request for an optional transformation in derived feature.
https://forum.onshape.com/discussion/5317/multiple-transforms-in-one-feature-within-derived
What I am now wondering is what other things am I missing that are right in front of my face!
https://forum.onshape.com/discussion/5255/derive-to-grouping-in-part-studios-improvement-request
Cheers, Owen S.
For my workflow, I don't try to repeat/instance parts in the part studio only drop parts with the derive for reference and I add the original in the assembly mainly because of BOM/Product/Assembly structure which is limited by the part studio lack of instancing. I use the part studio as the place for modelling and linking of parts, therefore my part studio will contain parts which make sense to be linked together but may be grouped completely different to the final assembly structure of the manufactured product.
