Fill command
Anwar_E
Anwar_E Member Posts: 4
Hello everyone
where can i find surface fill command?
tanks
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,273 image
  • Anwar_E
    tanks ilya_baran for the Answer
    but to be specific am new for onshape and i am modeling simplified room layout for CFD simulation as shown in the pic below
    so i want to cover the ceiling and the floor with surface so which feature can do the job?
  • ilya_baran
    Ah, I thought you meant something else.  That tool is currently under development and will hopefully come out soon.
    There are workarounds involving for instance thickening or splitting that will work when the face to "fill" is planar but I'm not aware of a fully general method that currently works.
  • billy2
    billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,181 PRO
    extrude, split & delete face.
    extrude:
    split:
    delete face:
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,092 image
    Create a sketch on the floor (using "use") then create an offset surface of zero - quickest way.
  • billy2
    edited April 2017
    Bingo! that's a new one:
    Thanks Neil,
  • Anwar_E
    Hi
    how can i merge or join several surfaces on same plane together and how can i cut through the surface?
    tanks
