Best methods/importing parts - Newbie question
scott_caskey
Member Posts: 55 PRO
I want to create a part repository where I make and store all the parts to my systems/equipment that I commonly use to build with. What is the best way to do that? Currently I have started one project and I am just adding part tabs for each part I make. Then plan to import them into other projects and build assemblies. Is this the best method? What is the best approach if this is not?
That is correct0
