the assembly studio does not automatically update when previously inserted parts are updated within
larry_ricigliano
Member Posts: 2 ✭
The assembly studio does not automatically update when parts are updated within the part studio? Is there a way to initiate the assembly update when parts have been updated?
If the part studio and assembly are within the same document then they will update to reflect the changes. If you are using a linked document, you must create a new version of the linked document and then you can choose to update it in the assembly. If you are still having trouble feel free to create a support ticket and share the document with Onshape Support.5
Bradley, I have multiple Parts Studio parts in the same document, but Assemblies (also in the same document) are not updated. From what you wrote, it sounds like it should update, but it does not. Could you clarify how to have the assembly update?
Note: when I right-click on a part and select "Change to version", it says "Newer versions available for 0 documents". However, in the history branch manager, it does show my changes.0 -
Hi @jblc
It would be easier to see what is going on in your document if you post a link to the document on this thread.Jake Rosenfeld - Modeling Team0
