the assembly studio does not automatically update when previously inserted parts are updated within
The assembly studio does not automatically update when parts are updated within the part studio?  Is there a way to initiate the assembly update when parts have been updated?
  • jblcjblc Member Posts: 3
    Bradley, I have multiple Parts Studio parts in the same document, but Assemblies (also in the same document) are not updated. From what you wrote, it sounds like it should update, but it does not. Could you clarify how to have the assembly update?
    Note: when I right-click on a part and select "Change to version", it says "Newer versions available for 0 documents". However, in the history branch manager, it does show my changes.
    Hi @jblc
    It would be easier to see what is going on in your document if you post a link to the document on this thread.
