Extrude to a vertex
gyrex
Member Posts: 37 ✭✭
Hi everyone,
I'm really new to CAD and I'm attempting to extrude a sketch to a vertex and hopefully have it taper to this point but I'm having some issues. Can someone help me please? I attempted to use the draft option but my extrude doesn't follow the wall lines and tapers to a point offset from the walls.
Also, is there a better way to start this sketch? I had to create a new plane offset from the top of the case, then created a new sketch on that plane. In that sketch I created a rectangle and then made the lines coincident to the inner walls of the box. Then created the triangle you see in the screenshot below. This seems like quite an arduous process for what I thought should have been an easy process.
Here's a link to the CAD: https://cad.onshape.com/documents/7acaac9aa46245186225afb6/w/239620736401d6f7997c98fb/e/eafacf164241373b2a38ee26
Thanks in advance for any help
owen_sparks
Member, Developers Posts: 2,660 PRO
Try a loft from your triangle to that vertex.
HWM-Water Ltd5 -
owen_sparks
I'd say plane creation was fine.
A couple of minor things though.
(1) Have a look at the "use" and "offset" sketch functions. They'll allow you to pick up/ project existing geometry onto your sketch, so no need for coincident constraints. Would also help where your triangular bits currently protrude into the case.
(2) Making all 4 of those triangular bits one at a time is the hard way. I'd have:-
Made one
Mirrored the part using the front plane
Mirrrored the (now 2) triangles on left plane
Or depending on your intent just model one then manipulate them in an assembly.
Cheers, Owen S
HWM-Water Ltd6
Made one
Cheers, Owen S
