Can I extrude with offset from the sketch plane?
Hi all,
I'm just curious with the extrude feature. I was wondering if I can extrude a sketch offset from the sketch plane? Whenever I need to create a solid off from the sketch plane I need to extrude(add) the sketch and extrude(remove) the length I want to offset from the plane. I remember this being an option in SW so I was wondering if there is an option in Onshape to allow me to perform the same action; instead of making two extrusion.
