Making a partial-depth slot around the surface of a cylinder
alan_budden
alan_budden Member Posts: 7 ✭✭
Given a cylinder (let's say 20 mm diameter), I would like to make a slot in this cylinder that is 3 mm diameter and goes 45 degrees around the outside of the cylinder, 0.5 mm deep.  This slot should match the result that would be obtained if the cylinder were placed in a rotary table on the milling machine, a 3 mm slot drill plunged 0.5 mm into the cylinder and then the cylinder rotated through 45 degrees.
I've tried a lot of different attempts at doing this, including:
* Create a plane tangential to the cylinder, create a sketch with a circle and then create a second sketch containing the 45 degree arc through which you want to sweep the sketch - I couldn't find a way to sweep it
* Create a plane tangential to the cylinder, create a sketch with a circle, extrude it and then try to stretch that object through 45 degrees - I couldn't find a way to stretch it
* Create a plane tangential to the cylinder, create a sketch and revolve it - the revolve wouldn't work
* Create two planes tangential to the cylinder, 45 degrees apart and two 3 mm circles - try to find a way to join them up!
Please can someone offer a method that would work for this?
