Will Gear Relations work on miter and bevel gears
david_sohlstrom
Member, Mentor Posts: 159 ✭✭✭
I have an assembly that will have several miter and bevel gears can I use Gear Relations on these gears so I get the part rotation I need.
Dave
Dave
David Sohlstrom
Ariel, WA
Ariel, WA
jakeramsley Member, Moderator, Onshape Employees, Developers Posts: 657Revolutes are mates that restrict all degree of freedoms except for spinning around the blue/z-axis of the mate connector. A gear relation is just a relation between two revolutes. It's essentially saying that when the first revolute goes around once, how many times will the second revolute go around. The revolutes can be as arbitrarily defined as you want.
While they are named gear relations, they can be used for any revolutions you want to tie together. One of our interns constrained some parts that would change from one kind of polygon into another based on rotations. It's just natural that two revolving things would be gears so we named it after that.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Dave
Ariel, WA
https://cad.onshape.com/documents/46b17dd88ed24f55bca2eb69/w/81cd48206e74495eb7d7dee1/e/76a995401969499bb4ca52df
Dave
Ariel, WA
Here is a experiment I dinged out. It should work for a partial rotation.
https://cad.onshape.com/documents/ebc649b6ae564e4ea7a04da7/w/11725af34d624fc29c56faa7/e/8b01e07502c74ea38472eae8
The big thing here is figuring out how to not get into mating hell by making a chain and joining all the links. It would be nice to be able to pattern not only the part but the mates of a part in a chain and link array.
Sad thing is that I likely will go and make a chain to work with this to show it can be done. UGH! A curious mind can be a massive OCD time suck some times @BruceBartlett what size of chain will work with your sprockets? 4L, 5R, 6N, 7N?? At least I am sure I could find the models for the links
LearnOnshape facebook group
It 1/2" chain, I attach the spec sheet in the doc.
also a good branching, test
Dave
Ariel, WA
Dave
Ariel, WA
Dave
Ariel, WA
Dave
Ariel, WA
(In theory, I should love relays and solenoids too, but in practice they often seem to let me down, so I've learned to avoid them when I can).
So one thing I've always wanted to try is to wire up two stepping motors in parallel as peer devices, with no external electrical power source, say for manual remote actuation of a (low torque) rotating device, or for remote indication of the attitude of that device, or both.
I mention it here because it's the purest analog I can think of to a "Gear relation".
Dave
Ariel, WA
Public doc https://cad.onshape.com/documents/46b17dd88ed24f55bca2eb69/w/81cd48206e74495eb7d7dee1/e/76a995401969499bb4ca52df
