transform derived parts based on part's edges in this part studio??
I probably just don't understand how to use transform by line but I haven't been able to figure this out:
I generate shapes for boolean cutouts and extrude them in a second part studio then add them as derived.  But now, I want to line them up a certain distance from my part's edge.  It seems simple but Distance parameters only work on sketches.  I'd like to do something like that to align my parts before subtracting.
  • here is the part I am making, I eyeballed it pretty well but I'd like to place the keyhole cutouts precisely:
    https://cad.onshape.com/documents/449e6909d42439adbd4ebb56/w/44610edf3ff8aa2132a6cdc8/e/c30fbe63094bf7f84aba24e6
  • To use transform by line, create a sketch and draw a diagonal line that represents the X & Y direction then use that line in the transform feature. You can also transform by XYZ or mate connector. Any reason you are doing it this way?
  • well just trying to do the logical step which is to make them a set distance from an edge.  This just seems to me to be the logical way to align objects and is more in keeping with the general construction principals I see in Onshape.  By this I mean that the over arching principal seems to be geometry in relation to other objects.  XYZ offset implies a global xyz coordinate system which is missing from onshape.  As it is now, if you change an object's dimensions then the cutouts will not move and must be manually reset into a new position.
  • Have you tried "Transform by mate connector"?
    https://www.youtube.com/watch?v=iO5UTK-ZYKI
  • Lyle_Walsh
    Yes that looks like what I am after, thanks
