Is there a way to add a sketch layout when importing a Solidworks Pack and Go Zip file assembly?
Paul_T
Member Posts: 2 ✭✭
Hi Paul, Onshape will only import solid and surface bodies. Even if it did import sketches they would not be parametric since they were designed in SolidWorks. If you want that kind of functionality you should remodel your assembly in Onshape.Senior Director, Technical Services, EMEA5
Thanks for the answer, I thought that would be the case but thought I would ask before redoing it.0
