Calculating leverage ratio.
nick_flyvbjerg
Member Posts: 3 ✭
I'm familiar with specifying linear relationships but I would like to know if Onshape can calculate a relationships for me.
example:
shock travel : wheel travel
I'm specifically trying to plot a shock ratio progression/regression curve.
example:
first you need to share a kinematic scheme of your suspension system, if we had a kinematic scheme, then my Tracer featurescript could possibly do the job
Sorry for the very delayed acknowledgement. Here is a kinematic scheme of my suspension system.
some dimmensions are missing on this cheme, so i defined them approximately. the output of tracer FS consists of two parts - the spline on the Top plane, that represents dependensy between driving and driven parameter, and the console output of the list of points in the format {{x1,y1},{y2,y2},...} where x is driving parameter, y- driven. You can copy that output and process in some math software using interpolation. Driving parameter is set by #s variable.
https://cad.onshape.com/documents/30bf0f8fce00281a0169dba0/w/880da44d026e97e242f8431e/e/6662531d541715d36727056c
