using patterns with extruded cuts
IsoThermIsoTherm Member Posts: 70 PRO
Greetings
I'm trying to make a circular pattern with an extruded cut. The cut (really just a hole) was made with a circular profile on a sketch. I can't seem to select the cut when I'm in the pattern tool, even when I'm on the Remove tab. I've tried it from the tree and from the model. It doesn't seem to want to grab the absence of something. I guess I can relate.
Thoughts?
Thanks
