using patterns with extruded cuts
IsoTherm
Member Posts: 70 PRO
Greetings
I'm trying to make a circular pattern with an extruded cut. The cut (really just a hole) was made with a circular profile on a sketch. I can't seem to select the cut when I'm in the pattern tool, even when I'm on the Remove tab. I've tried it from the tree and from the model. It doesn't seem to want to grab the absence of something. I guess I can relate.
Thoughts?
Thanks
Thoughts?
Thanks
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
Please, check that you select "Feature pattern" in the top of the Linear pattern feature.
You can check this document https://cad.onshape.com/documents/556785024e8ea12b4ff1a004/w/45110c3cc4d2d6e8047223c3/e/1db3cc7d275b83e23800f281Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común6 -
Jake_Rosenfeld
Moderator, Onshape Employees, Developers Posts: 1,646
This actually may be faster with 'Face pattern' than 'Feature pattern'. Make sure the sketch in question is hidden (so that it is not selectable) and select the inside of the face of the extruded hole as the 'Face to pattern'.
https://cad.onshape.com/documents/379ccf51e67e45199f498724/w/c83d7231119986cdddac5b52/e/a332229fa7dd68ee3c08b504
Jake Rosenfeld - Modeling Team5
