How to loft / fill airfoil shape across curved wing shape
sean_magee_saxton
sean_magee_saxton Member Posts: 3
edited August 2017 in Community Support
Hi all,
Trying to create / modify a design for a hydrofoil board.
I have a profile generator which I used to bring in airfoil shapes, and the keel extrusion was easy as it does not get narrower at the base.
I cannot figure out how to loft or fill from the foil shape along the main wing, as any attempt with various settings seems to fail to generate properly. I have sketched the profile of the wing, and want the airfoil shape to taper down to the end of the wing.
Can anyone help with this?
https://cad.onshape.com/documents/35bfbc7db86790e64fdfb278/w/7bd18c7c8caea5172144ec01/e/288027ee3e1b4dfb015d1615
  • philip_thomas
    philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381 image
    edited August 2017
    Ok - normally I just bang these out - but this was a head scratcher!
    Fun project! In the end @lougallo came up with a viable solution first! :wink:
    We hope this helps!
    https://cad.onshape.com/documents/be07bd204edb4c16883974aa/w/374412633a917855103be960/e/7c706709f8a630086048ee9a
    Philip Thomas - Onshape
  • o_krumm
    o_krumm Member Posts: 4
    Hi. I am quite new to Onshape and I am loving everything so far. I also tried to create a wing just like @sean_magee_saxton and found this post. I didn´t manage to recreate the steps from the file of @philip_thomas but I realized that the shape of the wing as seen below is not what you expect from a wing. It gets thicker in the middle although there is no spline that tells the loft to do something like that.
    Is there a way to work around that? And @philip_thomas : what was the breaking point in realizing what you accomplished by creating that wing? I always get error messages.
    With best regards, Oliver
