Featurescript: extruding between points.
jrs_spedley
Member Posts: 71 ✭✭
I've written a simple featurescript which involves extruding an edge into a surface. However, I'd much rather extrude between two points on an edge (the hollow dots) to make the sketch simpler and more flexible.
I've looked at line() which seems to create a positional vector rather than a line and can't see any way of creating an edge to extrude.
Any pointers for me? I'm sure I'm just not looking for the right search term.
That function takes an array of position vectors. If your input is a query with point entities, you can get the position with evVertexPoint.
https://cad.onshape.com/documents/0483eada7340f89d5d2934ae/w/f16a37f33184b47c5b9f1901/e/e7fd4de36625d83e9c12f801
