anybody know how to cut sweep this revolve along the path?
jakeramsley Member, Moderator, Onshape Employees, Developers Posts: 642
Currently no. I would probably do a sweep of the cross section then use the transform + copy part feature to position the revolve at the end caps followed by a subtraction.Pete_Yodis said:@McConnell113 Onshape currently handles only swept cuts from 2d sketches and regions. For your example, I don't there would be a geometric difference between the capability in Onshape and a swept cut of a body.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Saplingstore.com
The end caps of the sweep would have an extra revolve'd area removed which could be done as a separate operation.
Saplingstore.com
Saplingstore.com
Saplingstore.com
Saplingstore.com
Saplingstore.com
