Cycloidal Gear Generator
maximilian_schommer
Member Posts: 32 ✭✭
Hi Onshapers!
I just finished writing a cycloidal "gear" drive generator. It creates a cycloidal drive train using mathematically correct cycloid curves. I tried to make the UI intuitive. I hope all of the parameters that you would want to adjust are adjustable, but feedback on that would be amazing.
Try it out!
https://cad.onshape.com/documents/347e6a9ae9d0992f4b101a70/w/d85d62ab1c292cc0d3314104/e/39a63585c0c29cabbfacb536
Again, any feedback would be appreciated!
Maximilian Schommer
Try it out!
Maximilian Schommer
7
Where's our flattener?
You're right, I forgot to add the pin diameter circle to the feature list! Right now it's just half way between the outer bearing diameter and the outer pin diameter, but I'll make it editable! Also, what do you mean by pitch circle for outer and inner gears? Isn't that only useful for meshing gears?
Thanks for the feedback!
Maximliian Schommer
cycloidal gears are still the kind of gears that relies on kinematics of rolling pitch circles, so i think they bring rather important visual information. at least that may be an option. thank you
I added the ability to change the radius of the inner pins, and also added pitch circles. The pitch circles are different than what you'd expect for gears since they're dependent on the eccentricity and the number of pins (I think), but the ratios of diameters should be correct. I might have gotten the pitch circles wrong, so don't take my word for it.
Thanks again!
Maximilian Schommer
Awesome! I did (u)*e and (u*e-e), but fixed it now. I'm working on some more improvements to it and will push a new release soon!
Thanks!
this is a pretty old thread, but I've been making icons for some of my favorite features. If you like the icon and have time feel free to add it to your feature or ask me for tweaks. it's here.
Website: ovyl.io
One request: show the plotted cycloid sketch after the feature is created. I've been running into a bunch of issues with values not updating when assigning them with variables and having the cycloid sketch there would really help solve a lot of the issues I am running into.
