use variable in assembly
Hi,
I've been trying to use variable in assembly, but I'm not successful.
Who knows how can use a variable from part in the assembly?
Thank you
  • eric_pesty
    eric_pesty Posts: 2,851 PRO
    edited May 2025 Answer ✓
    Not if you uncheck the "Insert into all Parts Studios and Assemblies" checkbox. You can then manually choose exactly which variable(s) to import in any assembly.
  • owen_sparks
    owen_sparks Posts: 2,660 PRO
    Sorry variables only extend to PartStudios today.
    To what end do you wish to use them?  There may be another approach.
    Cheers,
  • mohammad_haji
    mohammad_haji Posts: 8 ✭✭
    To use in unpaired or not direct related to or more parts in 2 different assemblies.
    For example, relation between a cylinder bore to a lever in assembly. one number using for a 2 different type of calculation. Force & length.
  • mohammad_haji
    Why ca not use a variable number like this:
    #X@Part1 ?
  • jim_sung
    jim_sung Posts: 3
    I'm modeling a dining table.  I have a parametric variable called "reveal" that is used by other parametric variables that in turn constrain various parts, so it is needed in the Part Studio.  However, I also need the parameter in Assembly ("offset" in "Fastened mate"), but as pointed out by @owen_sparks, parametric variables are not visible in Assembly.
    I look at configuration variables, but I don't think it is applicable to my use case.
  • Scott_Morris
    Scott_Morris Posts: 17 EDU
    I would like to set the offset distance of many components to a variable so i do not have to visit all the connections to update the distances as things change.
  • _anton
    _anton Posts: 549 image
    You can drive your design from the top with a Variable Studio - those variables can be used in Part Studios and Assemblies.
    S1mon Posts: 4,482 PRO
    Ons solution would be to have some sort of a skeleton sketch that you can assemble your parts to. Build the offset distances into the sketches.
  • eric_pesty
    You can do this if you define your variable in a "variable studio"
  • daniel_melameth
    daniel_melameth Posts: 12
    @eric_pesty The problem with using a Variable Studio is the variables are shared across all tabs in the document.
  • eric_pesty
  • mohammad_haji
    Even though seven years have passed and so much has changed — new features, new updates, and all done by your successors — I really appreciate that you noticed my old question and took the time to reply. Thanks a lot!
