Combine a square and circle sketch shape
ts_sklett
Member Posts: 9 ✭
New to OnShape, new to CAD. I've drawn a circle and a square to define a shape that I want to extrude. What I can't figure it out his how to perform a boolean or to combine the circle and the shape to define my desired face that I can then extrude.
A picture is worth a thousand words...
I drew this (two separate sketch primitives: circle and square):
And I want to convert that to this (photoshopped screen shot to mock up what I want):
Any suggestions very appreciated.
-Steve
-Steve
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
You can use trim or simply extrude and pick the regions.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
However if you know that you won't need that inner geometry, go ahead and delete them with the Trim tool (M shortcut). Then you'll just have one region to pick when you extrude.
Depending on the complexity of the surrounding geometry, it can sometimes be difficult to get to all the regions to pick them - the key above the Tab key will bring up a picker menu that allows you to toggle through potential selections.
OnShape doesn't have a boolean operation in sketches.
Hope that helps!
