Where are all of Webinar video recordings?
StephenG
Member Posts: 385 ✭✭✭
Are all the past webinar videos, specifically the "What's New..." ones, available to view?
I cannot seem to find them.
@StephenG You can find webinar recordings at the link below.
https://www.onshape.com/videos/topic/webinars
6
6 -
Usually, I use Joyoshare Screen Recorder to record webinar, class lecture, speech, streaming movie, online gameplay, etc. in the way I like.
It allows me to add click effects, customize watermark, trim finished recordinUsually, I use Joyoshare Screen Recorder to record webinar, class lecture, speech, streaming movie, online gameplay, etc. in the way I like.
@yilia_yang You shouldn't need to screen record.
they should send you a link to the webinar if you participated. otherwise the rest of us will see the webinar once they get around to bulk uploading a hand full.
john_mcclary said:@yilia_yang You shouldn't need to screen record.
they should send you a link to the webinar if you participated. otherwise the rest of us will see the webinar once they get around to bulk uploading a hand full.Methinks this may be spam, he only has 5 comments and they're all for "Joyoshare"...OwS.
HWM-Water Ltd2 -
Well, could be, but I can only see 3 of the 5 posts.
They only mention "Joyo" in 2 of the 3, but all three are about video recording...
They even talk up ActivePresenter as a good program.
I would hazard a guess and say they are most comfortable with this topic to share their opinion so far. (Devils advocate)
It may be their foot in the door to feel out the community. I would hate to put a bad vibe to them unfairly, but I do see your point Owen.0 -
I quite agree and choose not to hit the report button on the grounds I might be wide of the mark. If so please accept my apologies @yilia_yangBusiness Systems and Configuration Controller
HWM-Water Ltd0
