sketching rectangles with non-vertical sides
123_456660
Member Posts: 31 EDU
I posted this a little while ago in improvement requests, but I think I should also post it here, as there is a chance that a solution already exists that I do not know about. https://forum.onshape.com/discussion/7865/sketch-rectangle-with-non-vertical-sides#latest
The trick is to delete the horizontal constraint
OK, take 2, how about a "Three Point Rectangle" tool, much like the existing three point circle function?
Owen S
