Error fetching toolbar information Error code -1
nathan_embree
Member Posts: 2 ✭
My laptop is a Windows 10 with the latest update. When i open up an Onshape file, i can see the object, but the toolbar on top is completely gone. It displays the message: "Error fetching toolbar information Error code: -1" My secondary laptop is also Windows 10, but the toolbar appears just fine on it. Any help would be appreciated.
@nathan_embree
Please first check this page: https://cad.onshape.com/check
If everything is green there, please get in contact with our support staff by pressing the "Report a bug" or "Feedback" button from the '?' menu in your document.Jake Rosenfeld - Modeling Team6
Just as a first level troubleshooting check, can you confirm that you are using one of the supported browsers (chrome, firefox or safari)?
Yes, EDGE, i am looking at you!
Philip Thomas - Onshape0 -
I am using Chrome. I knew that Edge doesn't work for some reason.0
@nathan_embree
If everything is green there, please get in contact with our support staff by pressing the "Report a bug" or "Feedback" button from the '?' menu in your document.Jake Rosenfeld - Modeling Team6 -
I still this OS should be able to detect if it's failed to load and redirect to this automaticallyJake_Rosenfeld said:@nathan_embree
O.S.
HWM-Water Ltd0
