Is it possible to extrude around an irregular surface / solid in ONSHAPE?
I am drawing up a test gauge for a 3D printing environment. The gauge features a number of moving conical inserts which are printed with different tolerances. This allows the surface precision performance of the 3D printer to be assessed.
I have tried using Boolean operators; in an attempt to subtract the overlaps  - but have not made any progress.
The surfaces to create the receiving holes for the test cones have been created using the REVOLVE function and then the CIRCULAR pattern tool.
  • philip_thomas
    philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381 image
    @martin_schyns - i am not really sure what you're asking.
    That said, if you post a link to a public document, the problem is usually solved in minutes! :)
    Philip Thomas - Onshape
  • owen_sparks
    owen_sparks Member, Developers Posts: 2,660 PRO
    Is it something like this?
    Linky
    Owen S
