Loft between top of shell and inclined plane
tgunr
tgunr Member Posts: 45 ✭✭
edited February 2018 in Community Support
Im ty to create a set  of inclined planes which I would like to join to top of a shell. However, when trying to use a loft it looks crappy as the loft looks like it is using a point on the shell as an unwanted vertices. How do you do this>
https://cad.onshape.com/documents/3c28a6a412a876425a7af44b/v/e811f7ca083c37339134c20a/e/22b4b87b8b95b7e3b4d84f9d
  • Jake_Rosenfeld
    Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646 image
    Hi @tgunr ,
    I looked at your document but it looks like you've edited away the root of the question.  Maybe set up a Version that has the geometry in question and post a link to that (rather than a link to the live document).
  • tgunr
    Corrected link
