Cannot create boolean, entities not contained
tgunr
Member Posts: 45 ✭✭
Trying to understand why I cannot create a boolean. I made the three outside pieces, then the middle. But why are they not intersecting?
https://cad.onshape.com/documents/3c28a6a412a876425a7af44b/w/e59a70434213b82c2c8e4527/e/b1133db8273d31f87c561b56
@tgunr
When an entity of your sketch is fully constrained (AKA has no more degrees of freedom it cam move on), it will turn black. This is achieved by adding constraints to the entities. Here is a helpful video on this:
https://www.onshape.com/videos/dimensions-and-constraints
And a useful course in our learning center:
https://learn.onshape.com/courses/fundamentals-sketching
@mbartlett21
You forgot to make your copy of the document Public.Jake Rosenfeld - Modeling Team5
@tgunr
In your Sketch 1, your lines are not constrained.
I have created a copy of your document with the constraints added here:
https://cad.onshape.com/documents/60a833d3126ca9a8c9364071/w/e2679e8e53fc72242cf61627/e/ce6d8f75fffc753dc804c9cf
P.S.
When you finish a sketch, all the lines should be black.
This will usually stop any problems with parts not intesecting0 -
That link takes me back to my document. I am not understanding what you mean about "all black" The only way I see them black is if they are "Used" in another sketch.
@tgunr
@mbartlett21
You forgot to make your copy of the document Public.Jake Rosenfeld - Modeling Team5 -
