How to flatten a cylinder?
philip_kukulski
Member Posts: 8 ✭
I have a tube with the end cut to meet another part. How do I unroll the cylinder to get a sheet metal blank?
skethc wrapper FS with unwrap option does it
https://cad.onshape.com/documents/0bb13c1b6ed6d4a6dd75cf99/w/b4493d47a45c27ce485c84b9/e/c8050a35a7417c12b801bd40
Or you could make the circle an arc.
You will then (hopefully) be able to extrude that as a sheet metal model0 -
I sketched a circle and extruded it. Then converted it into sheet metal model so I could get the flat pattern.
End result here in my wheelbarrow wheel:
https://cad.onshape.com/documents/c020bd6e1cd856abaa35cdec/w/72a9cb8fa8b48106a47c7d5a/e/f12ed1d7f5cb34491ba98a511 -
Two 180 degrees arcs together did not work. An arc ?? where the gap is on the order of the material thickness did not work. Arcs with larger gaps worked (extrude into solid, then convert). Still testing Chris'.mbartlett21 said:Or you could make the circle an arc.
I didn't extrude it. I had a solid cylinder (or one with a thin flat strip) and tried to convert it.0
The unwrap looks like it worked.konstantin_shiriazdanov said:skethc wrapper FS with unwrap option does it
Please tell me how to get the resulting curves into a drawing or sketch.
Thanks for the wrapping tool.
https://sso.onshape.com/documents/f537915e30a1eb7ecbfe16ce/w/9382762db8ba3ca7c3a2ca49/e/4b4c85ee8f5e5ffba069ce7e
it is not very convinient to unwrap closed surfaced for now, because you need to split them first and orient internal coordinate system correctly
https://sso.onshape.com/documents/bef4af2805bedca6cc39b26c/w/c604bea65d5141b25d086368/e/25f482063cfb6684529d7ccc
