ENUM LIST
papawopapawo Member, Developers Posts: 206 PRO
edited February 2018 in FeatureScript
can i add something in the enum list using user input in the precondition? is it possible?
  • mahirmahir Member, Developers Posts: 954 ✭✭✭✭
    Enums are basically constants. I don't think you can edit them at runtime. However, you can control visibility of individual inputs based on conditional logic. If the variability of your enum isn't too great, you can create multiple enums and have different list inputs using different enums. Then, depending on a previous input, you can choose which list input to show. Your postcondition would need to know which input to use.
  • MBartlett21MBartlett21 Member Posts: 1,798 EDU
    @mahir
    Couldn't he also use a Lookup Table?
    MB - I make FeatureScripts:View FeatureScripts
    @mbartlett21, yes that's true. I don't have any personal experience with lookup table implementation, but here's a helpful link.
    https://forum.onshape.com/discussion/comment/20104#Comment_20104
    @mahir
    Neither do I
