2D Designs?
christina_barfield
Member Posts: 2 EDU
Can you make 2D designs in Onshape? I want to do a project where we make game boards and then design and 3D print the game playing pieces. Can we do both parts in Onshape?
@christina_barfield
If you would like to make 2D designs in Onshape, you could use our sketching functionality, and then export those sketches as DXF.Jake Rosenfeld - Modeling Team0 -
I have done some layout work by using imported dwgs, sketch images, 2D sketches and 3D models in same environment. Two problems I encountered was sketcher performance on heavy dwgs and sketch images not showing once inserted into assembly.
I would still recommend trying, especially if 2D work is not too complicated. I think you should also consider thin 3D model instead of flat 2D boards.//rami0
