How do I select just a corner to be filleted rather than the entire edge?
cameron_shaw_doran
Member Posts: 14 ✭
I need to select the corners of the grip's not the entire edge
Step 18 in exercise: creating multiple parts in a part
studiohttps://cad.onshape.com/documents/e4c0e2d414ee836c98a71240/w/753c3b58f1ac84d191e85444/e/e44d38b59a044a4dbde034e0
You can only select faces and edges with fillet.
If you select multiple edges that intersect. It will give you a soft corner
cameron_shaw_doran you may want to try and turn tangent propagation off. It's on by default and picks the entire curve pieces if they're tangent. Sounds like you don't want this on.
Thank you both very much
I appreciate your help
it turns out it was something very simple!
I just had to turn the drawing to be able to select the side edges of it (not the front edge) the instructions picture wasn't very clear
