Counterbore depth
john_P37
Member Posts: 27 PRO
I have a rectangular block that is (say) 1.5 inches thick. I put in counterbores. The nominal depth for the counterbores would require long threaded screws (say, about 1.5" long) Is there a way to have the counterbore depth automatically reference off of the mated surface, so that the required screws are shorter in length?
thanks,
John
thanks,
John
@john_P37 - No, this is not currently supported. Please feel free to create an improvement request ----->>>>
(we do however automatically size the bolt diameter!
) Philip Thomas - Onshape5 -
If you're sneaky then there is a way today...(a) Set the counter-bore normally using the hole feature.(b) Use the measure distance featurescript to grab your reference dimension(c) Use either the extrude or move face function to deepen the CB with an expression of the measured distance.Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5
HWM-Water Ltd5
