Sheet metal 45 degrees flange
hobie_smithhobie_smith Member Posts: 34 ✭✭
If you attach a flange of 20mm length, measured from the radius to the outer edge, at a 45 degree angle (pointed) to a sheet metal model. How are you doing? I would like that this flange has 20mm, if I measure it it is always much shorter. Will link to an example.
https://cad.onshape.com/documents/4fb52b1f1060526730fa9864/w/1b4ef834c4083f079a0d5de5/e/3233f7b4df0cb79676760376
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    @hobie_smith
    Please try the "Sheet Metal Flange Plus" featurescript on this website
    https://featurescripts.bubbleapps.io
    For the curious, the flange distance corresponds to the length from the tip of the flange to the virtual sharp of the outside edges of the flange.
    @Jake_Rosenfeld
    My featureScript takes account of this and measures from the inside intersection.
    @mbartlett21 Nice addition!
    emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 859 ✭✭✭✭✭
    I have created an improved version of the feature sheet metal Flange.
    I can't share the code but here you can see a video:
    https://youtu.be/h4rMRUHU1Gw
    Improvements:
    • "Use model bend radius" with multiple sheet metal models
    • Set the distance measured from Inside or outsite
    • Remember previos values of Distance and angle
    • Set 2 diferent miter angles and added manipulators to set the orientation in each edge
    • Default miter angle changed to 90º
    Un saludo,
